Only net export
(@departamento_tecnico)
Hel­lo, we are using CHINTDDSU666 and we only get export to net, not home consumption.
At first we have incor­rect cable conec­tion on 1 and 3 conec­tors on the meter, and the readings were wrong. And when we cor­rec­ted that, only export to net. Is an F series.
Roz­po­czę­cie tema­tu Opu­bli­ko­wa­ny : 12/01/2022 4:39 pm
JaroslawRektor
(@jaroslawrektor)
Mem­ber Admin
You have to give it in cor­rect pla­ce in an home elec­tri­cal insta­la­tion.
Chint has to be as a first devi­ce in a main switch board.
Only then You will see cor­rect valu­es.
You have to switch on METER option in the inver­ter set­tings.
Con­nec­tion has to look like on the pic­tu­re below.
This post was modi­fied 5 lat temu by Jaro­slaw­Rek­tor
Odpo­wiedzCytat
Opu­bli­ko­wa­ny : 15/01/2022 6:04 pm
Hel­lo, for­get that dia­gram, becau­se this model of DDSU666 is not lon­ger sold. Now we have a dif­fe­rent conec­tion diagram.
Odpo­wiedzCytat
Roz­po­czę­cie tema­tu Opu­bli­ko­wa­ny : 17/01/2022 10:49 am
